sunny4691
Fell Off the Asembly Line
then, ucp series is a good choice.Go for it if you get a good deal.
Ok thanks
Avoid these at all costs. No compromise.prvprv said:1) how about iBall PSU? is it good or its
also like intex, frontech, zebronics?
You probably wont be needing a 500w unit even if you attach 5 Hard disks.prvprv said:2) When should I go for 500W PSU
over 350W? is it when i install a
graphics card? or when i attach 2 or
more new HDDs or ODDs?
No offence but I wont trust guys that want to sell power supplies that are opened and claim it was done only for "training" purpose.prvprv said:3) That guy fron NCIX.com in the
previous page showed some modular
& non modular PSUs. As they are
opened and used for demo purposes,
I am ready to buy any 1 of em for 2k
whenever you overclock you need more power.prvprv said:does OCing needs a higher Watt PSU?
( >350 ) ??
is the VIP brand psu any good??anyone has any experience?
intel dual core 3.0 GHz
asus p5gz-mx
2GB ram (1 stick)
1x160GB sata HDD
1 DVD RW
1x80mm fan
4850 1 gb
OVERCLOCKING (CPU) -yes
OVERCLOCKING (GPU) -yes
PSU ??
it depends on your upgraded components - if you want to go for a SB-E rig and multi gpu setup with cards like GTX 580s then you should look elsewhere but overall GS600 is a good PSU you can get and if you want a more future proof PSU then look for Corsair Tx850v2 @ ~7k or Corsair AX1200 ~18k![]()
