Hi friends. I assembled a new computer. I switched on computer and then tried to install Windows 7 using CD. It did partition of the new HDD and trying to install OS. After it completed 25%, generated error that it is unable to find some system file. I tried again and this time some other system file is missing. I have again tried and now it is unable to find Hard Disc to install OS. Then I tried checking BIOS and it couldn't find HDD. I tried to trace HDD 5 times via BIOS and once it is able to locate HDD. But unable to locate it during OS installation. Tried changing HDD cable, reassembling and also swapped CD ROm and HDD cables. It detects CD ROm but not HDD.
Also, I have noticed electric shock when I touch cabinet. Everything is brand new except MB and CPU (it was in working condition). I'm afraid my HDD is dead. Is it normal that in general cabinet conducts some sort of current or is that only if some computer part is not working properly.
I found that the earthing of my house is not proper and it(earthing pit) was removed/vanished as it is old house. Is there is any electrical product which can be used or I have to ask electrician to look into it. Or can I connect the earth pin to ground myself.
