karthik316_1999
Hello friends, just needed a quick but of advice.
Following a recent upgrade, I'm in need to upgrade my cabinet to the corsair carbide 500r
Carbide Series® 500R Mid-Tower Case - Carbide Series - Cases
Now this chassy includes 2x120mm front intake, 1x120mm rear exhaust & 1x240mm side panel intake fans. Learnt that it has capacity to hold 5 more fans. (2x120mm/140mm upper exhaust, 2x120mm front inner panel intake & 1x120mm/140mm bottom intake / exhaust fans ?? - Can someone clarify this for me ?)
Considering the fact that I've not overclocked by phenom II x4 system, could you please suggest which of these additional fans do i need ?
Requirements - The install should prove to be worthy of the money in terms of reducing the GPU & HDD temps considerably.
imo, installing a single top rear exhaust should be a good value addition & suffice. (As I would anyway take the removable hard drive cage out from the 500r for better intake air flow). For that, I had shortlisted couple of fans as below.
Please advice on possible choice, quoted market cost corrections, better alternates & also additional requirements if any.
CM Excalibur 120 mm (R4-EXBB-20PK-R0) - INR 1200
Excalibur - Cooler Master
CM BC 140mm Case Fan 1800RPM (Dual Ball/Rifle) (R4-BCDD-18FK-R1/ R4-BCDR-18FK-R1) - Can someone help me get the price of this?
BC 140 Case Fan 1800RPM (Dual Ball/Rifle) - Cooler Master
Air Series AF140 Quiet Edition High Airflow 140mm Fan - INR 1100
Air Series AF140 Quiet Edition High Airflow 140mm Fan - Air Series Fans - Cooling
Air Series SP120 High Performance Edition High Static Pressure 120mm Fan - INR 935
Air Series SP120 High Performance Edition High Static Pressure 120mm Fan - Air Series Fans - Cooling
Thanks for your time !
