Need help buying graphic card in 5k range urgent
anikesh
Hello
My configuration is Intel Core i5-2400 (3.10 Ghz), 2GB RAM, 20" LED monitor.
I want to buy a graphic card around 5k to play mission games like COD MW2, Battlefield 3.
Please suggest a good graphic card soon.
Cilus
laborare est orare
What PSU or SMPS do you have? Mention the Manufacturer name, Power rating and model number as exact as possible.
At a budget of 5K, HD 6670 1GB GDDR5 around 5.2/5.3K is the best choice. But 1st thing 1st....let us know the PSU first.
A
anikesh
Hello my cabinet is iball i8181 cabinet
May I know its PSU rating and necessary PSU required for HD 6670 / HD 6770 / GT 440 GPU
coderunknown
Retired Forum Mod
get FSP Saga II 500W. or Corsair CX430W V2. the former one should cost 2-2.2k & the later one will cost ~200 more but carries 3yr warranty whereas FSP offers 2yr warranty.
ashish21099
iball doesnt give good quality psu with their cabinets. So you definitely need to change your psu.
For 6670/gt440 you can do with FSP 350w or Gigabyte 380w. However for 6770 you will require atleast Corsair CX430v2.
your cabinet comes with iBall LPE/LPS 223-400 (250 W) power supply which is not enough to run any 5k gfx card - so you better take a look at Sams suggestion ;-)
A
anikesh
Hello
I want to know which one would be better......
SAPPHIRE HD 6770 1GB GDDR5 - Rs. 6656
HIS HD 6770 1GB GDDR5 - Rs. 7,344
MSi HD 6770 1GB GDDR5 - ₨ 7,107.00
Plz help me to chose the right one.......
Thanks.
dibya_kol
Hello
Thanks.
Pick up anyone, which suits u. But as all suggested early, u need a good psu first. 6770 need a 6 pin power connector to run. Don't take risks. If u were unlucky, ur psu might gift u a nice red paperweight for ur desk. Good luck ..
SAPPHIRE HD 6770 1GB GDDR5 - Rs. 6656 - 2 yrs warranty
HIS HD 6770 1GB GDDR5 - Rs. 7,344 - 3 yrs warranty
MSi HD 6770 1GB GDDR5 - ₨ 7,107.00 - 3 yrs warranty
Quality wise they all are good but it would be best if you can get R6770 Twin Frozr II/OC ;-)
dibya_kol
Another vote for Twin Frozer II/OC.
