loud sound from cabinet
anirbandd
go for 7770 @8k.. it a huge improvement over the 7750.. with the 7770 on 1024x768 you will be able to play cry3/gta5 with almost all eye candy enabled. i used a 7770 on 1024x768 for 3 months ;)
yep, getting HD7770 makes a lot more sense and stick with brands like Asus, MSI,Sapphire.
rst
rst
1. what about gigabyte 7750 or 7770 ??
2. What will happen to my inbult amd 3100 if I install 7750 or 7770 ?
rst
rst
today i bought power color 7750 graphic card
After installation of 7750 graphic card
idle cpu temperature is 40 C
load cpu temperature is 66 C
Is it normal ??
AMD Athlon II X4 635 ||Asus M5A78L-MLE ||aoc led - e2043fsk (20")||power color 7750 ||4.00 GB ram ddr3 ||500 gb hard disk + 1 gb external hd(W.D)
||Necola NPS-1004ST (450 W)
rst
rst
Ok, that's a descent price!!
and what about temperature ??
AMD Athlon II X4 635 ||Asus M5A78L-MLE ||aoc led - e2043fsk (20")||power color 7750 ||4.00 GB ram ddr3 ||500 gb hard disk ||Necola NPS-1004ST (450 W)
||epson TX121 printer||window 7 ultimate (32bits)
cpu load temp is on the higher side though Ok .. ramp up the cpu fan speed by disabling smart cpu fan control in bios but this may be noisy.
@ OP - reagding your query about max cpu load temp -- well, there's some confusion but 60c/65c/ mostly considered to be max safe load temp for AMD cpus.
Is it normal ??
It is normal temp but if it exceeds 79 C then problems may arise like artifacts likewise.
rst
rst
if max. load temperature is 79 C,then load temperature is not point of worry.
||epson TX121 printer||window 8 pro (64bits)
rst
rst
I have 7750 graphic card
But system information shows" 7700 series"
Is it ok ??
Even device manager is showing the same
Is there any software which show whole information ??(everest ultimate edition showing the same)
||Necola NPS-1004ST (450 W) ||epson TX121 printer||window 8 pro (64 bits) + window 7 ultimate (32bits)
tkin
Back to school!!
Is it ok ??
Absolutely fine.
