sanny16
Today i have taken new broadband connection which has a static ip address. Before i had MTNL broadband connection whose ip address was obtained automatically i guess. When i was using mtnl connection, that time the download speed in utorrent was good and the dht nodes numbers too without any tweaking but the new connection is causing problems. I have a bandwidth of 1 mbps and i am only getting 25 kbps speed even though the bandwidth allocation is kept high and the "set download speed" is unlimited, whereas i can download files from server or website at over 100 kbps. Where is the problem? do i need to tweak utorrent?
