While I was working on my pc yesterday it suddenly begin to behave
too much sluggishly so I restared my comp but found that it showed
disk read error occured - press ctrl+alt+del to restart & I was unable
to boot into windows. So I restarted & the same error occured again.
So I decided to find out the problem.
I booted my comp with bart pe boot CD & tried to recover data from the
80GB seagate sata hdd ( bought last year from vedant computers)
to my pen drive.. When I was going to access the E drive which has nearly
20GB of data it showed completly empty I recovered some data from F driv
& suddenly CRC error occured & I was unable to recover rest data. So I
thinked why not try the chkdsk. I issued chkdsk command with
chkdsk /f /r flag but the comp hanged.
Then I tried to Install XP by deleting all of the partions from 80GB hdd.
I deleted all partions & created a 15GB fresh partion & the rest space unpartioned.
A full format of C drive took around 20 minutes :shocked: When the format was complete
xp took around 40 minutes to install where it usually takes only 20-22 mins. Also
Xp's boot up time is around 2-3 mins now on fresh install :shocked:
After xp was installed I installed HDTune & check the 80GB hdd for bad sectors.
It showed some bad sectors. I am mentioning the test result in here :
I've made another three partion on the 80GB hdd to fix the bad sectors & fixed
them. But still the Hdd is way too slow. So I want tochange the hdd. Now I've
few questions - Guys please help me as far as you can.
1. Can I get a new hdd as replacement or they just repair my hdd with some software ?
( But I don't want a repaired hdd which will show new kind of prob some day later )
2. Will those bad sectors show up when I take the hdd for replacement.
( As if the bad sectors will not show up I will not get replacement I doubt )
3. What should I tell seagate people about the hdd ?- sorry for too much noobish Q
4. Should i take the hdd directly to the service center or give
the hdd to the shop from where I've bought it for replacement ?
** How much day it usually takes to get a replaced HDD ?
5.. Does segate has any service center near chadni, Kolkata ?
I'am sorry for the tooo loooong post. Guys please bear with me & give me
suggestion about the above questions
HD Tune Pro: ST380211AS Error Scan
Scanned data : 76288 MB
Damaged Blocks : 1.2 %
Elapsed Time : 22:57
1 Error at 26 MB (LBA 53376)
2 Error at 534 MB (LBA 1093688)
3 Error at 3007 MB (LBA 6160368)
4 Error at 3039 MB (LBA 6224040)
5 Error at 3071 MB (LBA 6291424)
6 Error at 3136 MB (LBA 6424144)
7 Error at 3144 MB (LBA 6440328)
8 Error at 5705 MB (LBA 11684656)
9 Error at 8535 MB (LBA 17480072)
10 Error at 9160 MB (LBA 18760096)
11 Error at 12801 MB (LBA 26218152)
12 Error at 15610 MB (LBA 31969608)
13 Error at 27420 MB (LBA 56157552)
14 Error at 28022 MB (LBA 57390872)
15 Error at 28607 MB (LBA 58588152)
16 Error at 28675 MB (LBA 58727656)
17 Error at 28699 MB (LBA 58776864)
18 Error at 36111 MB (LBA 73955600)
19 Error at 36575 MB (LBA 74906000)
20 Error at 39212 MB (LBA 80306528)
21 Error at 39349 MB (LBA 80587584)
22 Error at 39358 MB (LBA 80606456)
23 Error at 51592 MB (LBA 105662128)
24 Error at 51663 MB (LBA 105807520)
25 Error at 51848 MB (LBA 106185328)
26 Error at 51984 MB (LBA 106463312)
27 Error at 54232 MB (LBA 111068416)
28 Error at 54281 MB (LBA 111168752)
29 Error at 57699 MB (LBA 118168048)
