I just researched & found that my currunt GT 9400 is taking 50 w & HD 7750 will also take only 55 W
So Now please tell me only for extra 5 W do i really need to upgrade PSU ??
that's TDP not actual power consumptionthe gpu actually needs ~43w under heavy load and 9400GT needs ~29w.
This is it. The perfect clarification.theoretically the psu should be able to handle HD7750 but as it's an old psu do keep in mind that average wear and tear [ component degradation over time ] makes psus less capable compared to a fresh unit .. someone I know ran into trouble when he added a new HD7850 to his system [ the psu was vx550 - 5 years old ]. The psu ran fine with 6800GS but HD7850 was not possible even though both have only around ~30-40W difference.
I can assure you it will run with ease. Like I said earlier I've used HD 7750 with Intel e2140 with a 250W PSU came with HCL for nearly a year it didn't gave me any problems whatsoever. This card require very less power I mean it's Power consumption is almost same as 9500gt if not less.
Well what are the prices of a HD 7750 nowdays? I bought it on Octuber last year for about 6700(Gigabyte Overclocked edition.)
Now it's for 7k
ok guys so I finally ordered
Sapphire AMD/ATI HD 7750 1 GB GDDR5
Now many people are saying that I should change the PSU also, So plz suggest a good one atleast 450 w under 2.5k...
I have these 2 in mind...
1] Cooler Master Thunder 450W 450 Watts PSU
2] Corsair VS450 450 Watt PSU
Corsair VS450
I have it and TBH it hasn't given me any problems as yet
(Specs in my sig)
Also the local prices are cheaper than FK![]()
So do I and it's running my rig flawlesslyCorsair VS450
(Specs in my sig)
+1 for your order. Go ahead and GAME easily,at least in mid settings.By the way guys how is 7750 that i ordered?? For my 720 p monitor??
+1 for this comment by @rijinpk1.antec vp450p is much better. Dont go for cm thunder series or corsair vs series. atleast get antec vp450p by increasing your budget a little.it is worth and dont forget, psu is the heart of a system. If it is not good, none of the components function well.
A very GOOD card.
Friend RohanM buy the PSU with your judgement.
Well I have a HD 7750 paired with an i5 3470. It's pretty good considering how cheap it is.
My pc ran GTA 4 at you say ultra at 720p resolution with average 63 fps~(Benchmark) Haven;t played it much hardly one mission.
BF3 was about 50-55fps MAX at 720p (Ultra) but on some maps where it was crowded and **** fps would go down to 30-35.
Hitman absolution was about 23-25 and 30 at max at ultra settings 720p. (But sometimes it could go as low as 17-20)
Sleeping dogs was 55fps~avg at high and 30-35 at extreme.
Fifa 13 60fps mostly.
It's performance is considerably very good by looking at it's price. But mine is factory overclocked version. It's clocked 80mhz more than the sapphire's version you;'ve ordered. So there will be about 2-3 percent diff I'd say? dunno tho.
