it will fit. the corsair is a entry level PSU. measure dimension of current PSU and check with corsair on their site
OK,, so i tried that and found the following info
For Corsair==> Width x Height x Depth: 150 x 86 x 140 mm
For my psu==>Width x Height x Depth: 146 x 96 x 138 mm
Take into consideration error of +- 5% as i did it with a scale..
So according to this it should fit comfortably in place of my current psu..
Okay i think that cx430v2 will fit in my computer cabinet but looking at its pictures it seems that it has its fan on the upper side..
*img7.flixcart.com//image/psu/g/b/u/corsair-cmpsu-430cxv2uk-400x400-imad67hfnhkzyh2b.jpeg
So i think that would cause problem because my cabinet has vents on back side only and not on the upper side.
Please suggest something else which has fans on the backside and not on upper side..
