papashango_cs
Hii .
m using this config
amd phenom x4 945
ddr3 4 gb ( 2 x 2 )
W.D 500 gb
MSi hd6850 1gb
Under stress, (hardcore gaming)
The fan speed of the mobo, (6200 RPM) is this normal ? because i can feel/hear alot of Noise !
Idle RPM is btwn 2500 to 4000..
although the temp while gaming seem to be normal.
i have everything stock! stock coolers, No overclocking,
Temp under stress
Gfx - 72
Mobo 62
Process- 55
is everything fine.. i am always a bit extra concerned with these things..
m using this config
amd phenom x4 945
ddr3 4 gb ( 2 x 2 )
W.D 500 gb
MSi hd6850 1gb
Temp under stress
Gfx - 72
Mobo 62
Process- 55
