Temp and Fan Rpm seems weird. Help !
papashango_cs
papashango_cs
Reset your BIOS once. Something has gone wonky again. Fan gradient profile seems to be off.
Ok.. the thing is, i got my pc assembled from the shop owner. He also installed windows in it.. I DON'T KNOW IF HE HAD DONE ANY SETTINGS IN BIOS.. i lack knowledge in this ese things! Sorry! All I Want To ask is that wil resetting bios do something unusual?? Like i just want it to be working perfect.. i cant do settings! And if it's safe! How to reset bio.. is there an option to do this in the bios itself!?
resetting bios setting will not do any harm to your PC. Your mobo must have come with a instruction manual - follow that to know how to reset/clear CMOS setting.
There's a simple way to do it though - power off your system and remove the coin sized big battery from the mobo and put it back on after say a minute or two - this will reset your cmos setting.
After doing that the bios will prompt you correct a couple of bios setting - just follow the mobo manual to set them correctly.
