Suggest a 20" led lcd monitor!!!!!
justme101
" It'S iN tHe GaMe..."
ok so i need a 20" led lcd monitor (preferably lg or samsung, though i don't mind others)..
i was searching online for monitors and i got confused when i came across a fact about there being more than 1 type of DVI port ( my graphics card has a DVI-I DUAL LINK PORT) and i saw a LG monitor ( Model : E2060T ) which had a DVI-D DUAL LINK PORT
So, will the monitor not work???
P.S. the price range is a MAXIMUM of Rs.7500
saswat23
For your budget you can easily get a 22inch HD monitor. So, why are going for a 20inch then. Go for BENQ G2220HD for 7k.
For 20inch choices are:
* DELL IN2020M HD-LED -- 6.2k
* SAMSUNG B2030 -- 6.4k
* LG E2040T -- 6.3k
justme101
justme101
* LG E2040T -- 6.3k
I searched for LG E2040T on the LG website but it's not there!! Is it discontinued??
and I was actually thinking about LG E2060T. How's that??? (It looks really cool u know) :cool:
but i believe it's priced higher????? :(
saswat23
Whats the price BTW..???
Then why don't you go for G2220 HD. You will surely not be able to know the LED diff.
justme101
justme101
The price on a website showed 7400/- and on another it showed as around 10000/- but there weren't any dates so it's hard to figure out the exact current price. May be going tomorrow to buy it. I'll check it out.
Might as well go with BenQ.
