Speed problem with BSNL Unlimited Broadband @Rs. 750 ...
koolent
Hi, I have a BSNL Broadband with teracom modem and unlimited plan..
I have very low speeds here in:
Rawatbhata(Via-Kota), Rajasthan, India
The download speed is abt 20 kbps - 35 KBPS MAX..
AND
Upload Speed is 50 KBPS MAX
I think that is nt enough for broadband.. How can I fix it ??
y2j826
All the Unlimited plans are upgraded from feb 1, 2010 therefore there are some technical issues with the new plans in upgradation, it may start working fine after some days...
MegaMind
A BB connec. with 256Kbps will have download speeds of ~30 Kbps & ~60Kbps for a 512Kbps connec.
With BSNL Unlimited Broadband 750, you'll have download speeds abt. 120Kbps till 6GB of download & after that it reduces to 60Kbps..
koolent
koolent
Download spd = 0.05 MBPS
UPLOAD SPD = 0.07
PING = 1580 ms
UPLOAD SPD = 0.07
PING = 1580 ms
MegaMind
.05 MBPS for 750 plan is around the actual speed you are supposed to get.
OP should get 0.5Mbps not 0.05..
@koolent, i have the same plan ULD750 this is my BB speed after exceeding 6GB usage..
*www.speedtest.net/result/1778485595.png
thetechfreak
Legend Never Ends
koolent there is something wrong with your line
100% sure. get it fixed. even i had speed like this. became normal after line was fixed
koolent
koolent
Yippee.. I don't know what happened but anything which happened is really sweet his is the result now:
[URL=*www.speedtest.net][IMG]*www.speedtest.net/result/1784376048.png[/URL][/IMG]
Its also exeeded 6 GB.. :)
This is pingtest.net result.
*www.pingtest.net/result/57264508.png
Sakar
Still a lot to learn
I also have the same problem. I live near him. My cousin lives about 2 km away with the same plan but still he is getting download speeds upto 190 kbps.
koolent
koolent
You guys have magic.. These are my download speeds now..
*www.speedtest.net/result/1793303641.png
and pingtest.net ping:
*www.pingtest.net/result/57568575.png
koolent
koolent
Noo... The speeds are back to where they were:
*www.speedtest.net/result/1806219538.png
What shud I do ? My speeds shot up and are agn down. Is there seriously anything wrong with my line..?? The speeds were up for abt 5-6 days.. Shud I talk to the BSNL Guy or shud I go to the exchange office ?
Renny
Change the mode from ADSL2+ to G.DMT in your router's configuration page, also check SNR/Attenuation.
mr-moustache
try changing your DNS server . even me i had a shitty speed before i changed my changed my DNS server since BSNL server are **** or its that they just dont care.
Am posting two results of the two DNS server am using :
*www.speedtest.net/result/1806240190.png
*www.speedtest.net/result/1806232564.png
juts letting you know that before changing my DNS i use to get download speed of around .34 mb/s
my plan is BB Home Combo UL 750
