Quad Core System CRASHING HELP HELP !!!
Renny
try with some other ram stick and see if bsod's occur again. .but u should change ur psu even if ram turns out to be faulty.
My Amd athlon x2 3800+ system was also crashing on an iball 400W PSU!
Its the PSU, get urself a 500W PSU.
P
Padikkal
My Problem had been solved. The brand new-sealed Transcend 2GB DDR2 RAM replaced. The memory test is successful with no errors.
Thankz for all replies, advices.
nithinmohantk
Hostage Negotiator
My new system crashes very frequently with blue sceen.
Could not use the system due to failures, loosing DVDs & CDs.
Installed XP on drive D: Installed Vista on Drive J: Same condition repeates.
Config:
Intel Q6600
Inel G33 FBC
2 GB DDR2 800 MHz Transcent 5-5-5 Single strip
160 GB SATA Seagate (D-20, F-10, G-40, H-40, I-20, J-40)
40GB PATA Maxtor OLD (C-20, E-20)
400W iball SMPS Cabinet
DVD writer SATA
1. Re-Installed Xp,
2. Inserted memory in another slot,
3. Updated BIOS,
4. Removed the OLD HDD(40 GB).
5. HDD SATA port changed
Kindly Help !!!
Similar postings are searched, Could not find proper reply.
Powersupply man. change the power supply(SMPS).. 400 W IBall will deliver a maximim of 300W only.. So it's not efficient enough to work with Quad cores buddy..
4 Cores need more power..
More Power needs a better PSU.. go for a 500W or 600W Cooer Master .. coller Master Extreme 500W will cost 2850/- @ www.primeabgb.com
it's good to heard that your problem had solved. But pal do change the psu to atlest 500W one . Look for brands like antec, corsair, coolermaster, transcend. It's important for your proc and should give you better room for future upgrade like a gfx card for gaming -as g33 core is not very good for gaming.
shivg33k
I s33 G33ky p30pl3
The PSU is the culprit.. Change it immediately before it does some serious damage to your system. in my opinion get yourself Cooler Master Extreme Power 600W costs within Rs. 4000. its gives value for money and performance, i don't know the price exactly its good and powerful enough to provide juice for your setup.:D:D:D:D:D:D:D:D:D
ace
hiii
you can use this site to find out the right power supply for ur system
*www.extreme.outervision.com/psucalculatorlite.jsp
