Kalyan
This might be a noob qn. but I don't understand the complete operation of my APC ups. I am using APC UPS ES 650. there is only one button, two LEDs, one reset button. pls clear me if what I am doing below is normal or not.
1) When the ups is off and is charging, there is no indication. The indicator light is on only when the ups is on..
2) I normally press the button once, hear a short beep and then, the amber light flashes for some time (I think this is self test. does it have to run every time?). The same to switch the ups off.
3) As per the manual, holding the button for 10 sec would switch to program mode to choose high / med / low levels.
4) Is there a way to switch the ups on when there is no power..
I am a bit confused because, the same button is being used for various operations and APC doesn't provide the operation in the manual. only trouble shooting is listed.
Thanks a lot..
Thanks a lot..
