theterminator
I have a 600 VA Intex UPS & an iBall Cabinet cum PSU which I think is 350 W , don't remember the exact wattage but it cost me Rs. 1000 (Cabinet + PSU).
~100 WATT
btw G2020's IGP intel HD 2500 is better then Geforce 210 so no point in using that(Correct me if i am wrong)
So better sell it it will reduce some load/power consumption
my measurements with clamp meter says that usual desktop PC draw 250 to 350w watts. cheapest budget PC draws 100 to 250 Watta. high end gaming PC with multiple hdd draws 300 to 600w.
How do you calculate the power usage cost from that?
> The tariff is applied on number of units consumed.
> One unit = 1 kWh = an appliance rated at 1 kW or 1000 W run for an hour.
> Suppose your PC's average power consumption is 'x' W and your region's electricity tariff is Rs. 'y' per unit and you run the PC for 'z' hours daily, then your monthlr charge for running PC will be : [((x/1000) * z ) * y] per day.
So at 390w usage with 10rs per unit and 12 hours a day comes to 46.8 rs a day. That sounds reasonable enough. I'd probably add 20 rs more for 2 monitors per day.
i got myself a clamp meter and measured the conpumtion in watts of my pc(uintel g620+gigabyte mobo and all other accessories with tvs printer)
it was 0.2A
means
240V x 0.2A=48W
^^voltage in home is RMS(220/240v) so no need to convert it to absolute/peak values & assuming sine wave(should be true for govt power) even cheap/typical multimeter show correct rms voltage value only for ac voltage.bill is determined by energy consumed & this in turn is decided by V(rms)*I(rms)*time.since psu in pc convert ac to dc with efficiency ranging from 50-90%(depending on psu & load) there shouldn't be much difference between I & I(rms) so above calculation should give close approximation of power consumed.
i am not familiar with settings of "hall effect" power sensors but it seems like it measures instantaneous power or in other words it acts more like an accurate conversion of AC to DC power so it shows actual power being consumed at that instant which would be less than AC rms value since it fluctuates continuously.maybe your meter is set as too accurate & to get rms value instead of accurate instantaneous value it will need a settings change.
