Building a PC Gaming rig for <60 k - need help
weemundo
What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: Coding and Gaming
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: Why the hell not?
3. What is your MAX budget?
A: 60k
4. Planning to overclock?
A: Nope.
5. Which OS are you planning to use?
A: Win 7 HP.
6. How much hard drive space is needed?
A: ~500 GB
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A: Whatever is the best at given price - tbh.
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest)
A: 3.14
A: Never. This will be done by an assembler.
10. When are you planning to buy the system?
A: this very month
11. Are you one of the types looking out for "future proof" configurations?
A: Absolutely
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention.
A: UPS
13. Which city do you live in and are you open to buying from shops from other city/states?
A: Bhopal
14. Mention any other points if deemed necessary
A: i7 sandy bridge and nvidia GPU is a must. Basically, I need a gaming rig - so a kickass graphic card is essential. My hardware knowledge is pretty much non existent so - any help appreciated!
rajatGod512
N00B Troller
Core i7 2600k - 15.9 k
MSI Z68A GD55(B3) 9.8k
Gskill DDR-III 4GB Desktop Ram -Model F3-12800CL9S-4GBXL 1.9k
Seagate Barracuda 7200.12 500GB 1.9k
MSI N560GTX Ti Hawk 1GB 14k
Corsair GS 600 4k
Cooler Master Elite 431 Plus @3.2k
LG DvD Writer 0.9k
Benq G2220 HD 7k
Logitech MK200 0.7k
Logitech Z313 1.5k
Total = 60.8k
You can also Opt for AMD HD 6950 2GB as your gpu as it is better than nvidia gtx 560ti
MSI HD6950 TFIII/OC will cost you about 16k
Cilus
laborare est orare
For gaming and coding, i5 2500K is more than enough. Here is my suggestion:-
Intel Core i5 2500K @ 11K
Gskill 1600 MHz 4GB X 1 F3-12800CL9S-4GBRL @ 1.6K
Seagate 7200.12 500 GB SATA HDD @ 1.9K
MSI HD 6950 2 GB Twin Frozr III/OC @ 15.8K
Corsair Gaming Series GS700 700 W @ 5.1K
Cooler Master Elite 430 With Transparent Side-panel @ 2.6K
LG 22X SATA DVD R/W @ 0.9K
BenQ G2220HD LCD @ 7K
Logitech MK200 @ 0.7K
Logitech Z313 @ 1.5k
Total 57.9K. Added a more powerful GPU and a high watage PSU for future upgrades.
Tech_Wiz
nVidia Alternative as posted by you:
GTX560 Ti HAWK Edition or GTX 570. Both are within your budget.
Performance wise
GTX 560Ti < HD 6950 < GTX570
Cilus
laborare est orare
The reference models of GTX 570 has some VRM problems and in many cases the card have been burned. Only the custom VRM design models like MSI Lightning or Asus Direct CU II models are free from those issues and price is also very high, like 21K.
W
weemundo
Thanks a ton folks! Can you suggest a better keyboard / mouse combo as well along with better monitor <10k (I'll extend a budget for these two).
Cheers!
Cilus
laborare est orare
Then get BenQ G2222HDL 22" LED Display @ 9K. It is a very good display. For Keyboard/Mouse Combo, get Razer Cyclosa gaming bundle @ 2.2K.
d6bmg
BMG ftw!!
My vote for BenQ G2222HDL. As it is very good monitor at ita price range (i.e. 9K). You can opt for it without any second thinking.
W
weemundo
Hey folks, firstly thanks for all the help. I just need one more info from you guys - so I thought of bumping this thread.
Can you guys suggest alternatives for mobo -MSI Z68A GD55(B3)
and an alternative for 500 GB HD.
Please suggest an alternative that is cheaper then the one mentioned above.
Again, help appreciated ! :)
Cilus
laborare est orare
Sorry bro, can't help you here. In fact, you should have made the HDD purchase earlier. Currently due to flood in Thailand, the price of HDDs have been increased like hell, sortage in production.
Now 500 GB HDD will cost you around 4K, in fact, little more than that.
And MSI Z68A GD55(B3) is the best VFM Z68 board within 10K. There is no alternative available with the same features and performance offering.
W
weemundo
Hey Cilus, thanks for all the help - first and foremost.
The thing is - The rig is being assembled and MSI Z68A isn't available. So I need an alternative - anything less than 15 would work now I guess..so please post relevant alternatives please. The configuration is the same as you previously suggested.
Cheers.
rajatGod512
N00B Troller
Asus P8Z68-M PRO Motherboard @ 10k
OR
Asus P8Z68-V Motherboard @ 13.5k
OR
Asus P8Z68-V PRO Motherboard @ 14.5k
d6bmg
BMG ftw!!
Asus P8Z68-V PRO @14K is the best option that you can get under 15K
You may also look at Gigabyte Z68X-UD4-B3 @13K
