audio not working -"no audio devices found " in control panel
My friend is having problem with audio ON HIS PC....
In CONTROL PANEL->SOUND AND AUDIO DEVICES->NO DEVICES FOUND
I formatted the pc , while installing realtek drivers the setup did not detect any audio devices..
I think its a harware issuse ..
any suggestions ??
Thank You
dashing.sujay
Moving
This error is mostly shown when no audio drivers are installed. I encountered almost same problem. I just tried uninstalling the audio drivers and updates related to it. Although initially it didn't worked out, but after some retries and restarts, I was able to do it. Its least chances there's any hardware problem. If nothing works, give a last try by reinstalling OS.
^^ He already tried reinstalling the OS.
@ Op - what OS you have installed ? Xp or Win 7. IF Xp try installing this
Microsoft UAA Bus Driver for High Definition Audio
More info about this ;-)
If this is not working just get a cheap sound card ;-)
d6bmg
BMG ftw!!
^^ After installing MS UAA bus driver re/install your audio driver and your audio device should work fine.
