Hello-
I need to install a 1 Ton split A/C soon and I've got a 5kVA servo stabilizer serving the entire home. Do I need to have a separate voltage stabilizer for the A/C unit ? The existing servo-stabilizer has a power on delay 1 sec to 5 mins-selectable range. So my question how much time Delay between two consecutive power ON for split A/C is advisable for the better life of compressor ? Or time delay doesn't matter and only high/low voltage protection is sufficient for split A/C's ? Pls advise.
