Hello everyone.
I have a query about the system that we are about to purchase for our college. Our faculty has a requirement for a high powe pc. with 8 gigs ram i3 processor and good graphic card,, which will be used for editing videos and pictures basically for multimedia.
There are two machines we can buy. one is workstation form hp and another is imac. our budget is around 75 k for each machine.
please suggest.
1st of all, remove the thought of Core i3 processor. It is a lower end model from Intel and not at all suitable for the kind of work you've mentioned. You should be opt for at least a true Quad core processor.
And @ 75K you you get an assembled PC, it will be far better than anything you bought from HP or other companies.
However I'm suggesting a assembled configuration for you.
Processor: Phenom II X6 1090T Black Edition 3.2 GHz (6 cores, 3 MB L2 Cache, 6 MB L3 cache) @ 13.4K
Motherboard: MSI 880GMA-E45 (With SATA 3 and USB 3)@ 5.8k
Ram: Kingston 4 X 2 GB 1333 MHz C9 DDR3 @ (1650 X 4) = 6.6K
Cabinet: Cooler Master Centurion 690 @ 4.2k
Keyboard & Mouse: Microsoft Comfort Curve @ 1K
Hdd: Seagate Barracuda 7200.12 2TB (32 MB Cache) @ 4.9K
Optical Drive: LG 22x SATA DVD Writer @ 0.9K
Display: BenQ 24" G2420 FULL HD LCD Monitor (max resolution 1920 X 1080)@ 11.3k
Power Supply or SMPS: Corsair VX750W @ 6.45k
Graphics Card: Zotac GTX460 1GB GDDR5 @ 12.7k
total 67.25K. This configuration is more than enough to satisfy all your needs. A 6 core is capable enough to run the multi-threaded applications in blazing fast mode. 8 GB ram is actually a overkill. The cabinet will give you good air flow to keep the monster cool. 2 TB HDD is I think enough for a server. BenQ G2420HD is a very good LCD monitor and working on it will be fun and easy.
The Power supply is capable enough to run your current setup and also open for any possible future upgrade. The Graphics card is a Nvidia one which will offer CUDA and GPU computing. Most of the multimedia applications, now a day, are capable of using Graphics card to enhance their performance dramatically. I've suggested Nvidia card because CUDA is little mature than the ATI stream and number of applications supporting CUDA is little higher.
In the configuration I have not used the whole budge you have specified>.The reason is when you buy the System from a Company, normally they provide the OS and the basic software. Here you have to purchase them separately. So use the extra money for it.
