strange problem.please help
quan chi
mortal kombat
well guys i dont know if its a problem or something else.but i think i have not noiced it before.
well its like this whenever i click on any s/w shortcut take it as my doumentsin windowed mode not in fullscreen mode .
when the windowed mode pops up there is a slight 'contraction and elongation type in the desktop also'.i mean if the menu pops up in windowed mode then at that instant the other icons on the desktop also contracts a little and then comes to their original shape in a fraction of a second.
same thing happens whenever i closes that window.
and also whenever i play gif through windows picture and fax viewer.
the window playing the gif (including the start and tray icons at the botton.)
starts to expand or contract (or vibrates) with the gif.(according to the movement of the gif.)
and some times though very rare the icons also blinks without any reason.
i have windows xp professional sp2.
well what is the problem can anyone please help.
RCuber
The Mighty Unkel!!!
That might be a work of a prank program or even a virus. Please post you desktop screen shot and also the processes running in task manager.
quan chi
quan chi
mortal kombat
here are the screenshots.
*aycu18.webshots.com/image/26097/2005796487534103896_th.jpg*aycu13.webshots.com/image/23012/2005779151159604972_th.jpg
RCuber
The Mighty Unkel!!!
^^ Look like you have used some kind of theaming software that might be the culprit. Never seen such a problem .. Try logging as another user and check . I strongly recoment that you dont use Administrator account for regular use.
quan chi
quan chi
mortal kombat
i had previously used but now i dont use it.please do reply if you have any solution.
RCuber
The Mighty Unkel!!!
Just try creating a dummy user and login from that account and check. I think the problem exists in theming..
or wait for others to suggest.
Liggy
Is actually a real word..
try a cleanboot (removing unnecessary startup/services from loading) through msconfig. ***remember to put checkmark in hide all ms services on services tab*** (but leave anything that says symantec..unless you think norton is root cause)
if you're still getting prob post a hijackthis log here, see if there is something causing the prob
