strange problem, help me
paul_007
my pc is behaving strangely since last 5 weeks
i'm using windows XP pro and my pc straight away shuts down(as if someone has switched off the switch) on follwing occasions without giving any message:
1)whenever i add files to a zip or rar archive
2)whenever i am about to make CD iso image in FANTOM CD
3)whenever i extract files from zip/rar archive files bigger than 200 mb
4)whenever i add songs in winamp playlist
pls help me
rajas700
I think it may dude to lack of space in ur c: or else check paging file and adjust according to ur ram....
ymhatre
Hey dude (rajas700) ur correct.
If the problem persist then just format ur hardisk .
Still if same then its Haardware problem related too power box.
And Paul do specify ur configuration. tht may help is analysing the problem.
QwertyManiac
Commander in Chief
Before a format/repair, do a re-install of the compressor and set only one as primary, must be some kind of conflict between many compressor s/ws prolly :(
P
paul_007
my config is
p4 2.26ghz
128 mb ddr ram
intel 845 , 32 mb onboard memory
20 GB HDD
there is still 2.36 GB left in my C drive
efore a format/repair, do a re-install of the compressor and set only one as primary, must be some kind of conflict between many compressor s/ws prolly Sad
i am only using winrar[/code]
Kniwor
Learner
if it shuts down at other cpu intensive tasks may be u have set some shutdown temp in bios and it´s touching that
rajas700
TRY TO TURNOFF SYSTEM RESTORE.BECAUSE some virus may hide in system volume information and that part antivirus won't scan.so try by turning off ur system restore and post ur comments.
mohit sharma
i think with p4 nd xp u need to have a think about the meagre amount of ram , u should go 4 additional ram too , although the actual cause is temperature definitely as told by kniwer
