satbir wrote:
hey all........ this may sound dumb......... but giv a try ashu........ open sound controls and mute line in........... its kinda strange but i recently got rid of a similar problem by muting line in
check this
*www.thinkdigit.com/forum/viewtopic.php?t=35768
Well thanx for ur reply buddy,i Muted the LINE-IN, but no luck. Actually wat i tried is.. jus setting the pin (wich goes into the woofer) in such a way tat i can hear sound from both the speakers... Strange !! isin't it !!
I noticed tat if the pin (wich goes into the Woofer) is inserted fully inside,then i hear sound only from LEFT speaker,but if i remove the Pin slightly outwards (away from the hole and not completely inside) then i hear sound from both speakers....
As of now,my problem is not solved and then i tried to plug in my headfone as well as my Walkman earfones, and in both the cases,I can hear sound only from one side of headfone as well as earfone. So i guess i hv to get a new Sound card.
I enquired from the shop and he told me tat the
Creative Vibra 128 sound card (for a 2.1 speaker setup, i suppose..
) is priced at Rs.500/- with 1-Year warranty. So is this sound card good enough or is the shop guy fooling me ?(giving me a cheap sound card with a Fake "Creative" name?)
Cheers n e-peace.....
