se if there is any cd/dvd in the optical drive if yes then remove it if the sound is coming just when u switch on the pc & disappears when windows is loaded then it is ok
No Mithun there wasn't any cd/dvd in the drive.se if there is any cd/dvd in the optical drive if yes then remove it if the sound is coming just when u switch on the pc & disappears when windows is loaded then it is ok
Its seems like one of the fan inside your system is having problem. Open the cabby and check if some wire(s) is touching the fan blade.
Remove the cabby cover and start the system, check which fan is making the noise.
@ajayritik: I hope u have cleaned your system.use speed fan to check the fan speed & temp
