phanisrinivas
Quick Shooter
I have Zen Stone Plus player...
Once I was not click safely remove , i removed quickly..
Next , when I connect the device , it was not open ...
" dailog window" shows like "Disk Drive is not formatted, Do you want to format it".. then i click "Yes"
Again t shows " The disk in drive <> cannot be formatted"
1. In command prompt " format H: -> It shows " Insert new disk for H: drive, and press enter when ready"
2. I used HP Disk Format tool for formatting " in that the device cannot be found"
3. I use Creative firmware tool, that was also shows " device was not found"
Is there any hotfixes for removable devices ...
PLEASE HELP
Posted again:
Please help??
PLEASE HELP
Posted again:
Please help??
