problem with asus z68 pro
fukra
hey guys ! i recently bought new z68 mobo . i have installed all the software but i,m not able to install lucid virtu .when try to install it it say the error "intel sandy bridge graphic system or drivers not found ,but i have 2500k .i have installed all the other software except this ,plz guide me
Faun
Wahahaha~!
^^enable the setting in bios for integrated graphics card.
*benchmarkreviews.com/images/reviews/motherboards/P8Z68-V-PRO/asus_p8z68v_pro_bios_virtu_modes.jpg
saswat23
yes, to install and use lucid virtu you have to enable thee iGPU, else whats the use lucid virtu.
BTW whats the max VRAM/iGPU memory of the mobo..
tkin
Back to school!!
Faun posted two different pics, the first pic is for if you want to use onboard graphic card, in that case you don't need to use virtu.
The second pic is for using a separate graphic card, in that case you can use virtu, first you have to install both intel graphic card driver and nvidia/ati graphic card driver, then install virtu.
F
fukra
i have enable the igpu but the install error not gone from where can i download intel sandbridge graphics driver
Faun
Wahahaha~!
Please see tkin's reply in bold.
yes, to install and use lucid virtu you have to enable thee igpu, else whats the use lucid virtu.
Btw whats the max vram/igpu memory of the mobo..
64mb iirc.
F
fukra
thanks guys prob. solved but i have another ques
i have corsair venganance 1600mhz 4 gb ram but it run at 1300 mhz why?
F
fukra
thanks tkin genius
i wanna ask u another prob .
when i start up my pc my bios show cpu temp 65 c but al suite and other software show temp around 45 c
tkin
Back to school!!
thanks tkin genius
When in bios no power saving tech is applied, so processor runs at full clock speed, also bios puts some load on the processor as well, hence the high temp.
In windows, the temp you see is idle, the processor downclocks to 1.8Ghz and hence the low temps, everything is normal.
