Artemis
The Last Puff
Need to buy a Power Supply for my PC, decided on a FSP 350w but its not available here, so please recommend me another for not more than 1500Rs.
Please reply fast. Also Samsung B2230 is quoted for 8900Rs. Is that too much?
Any other monitors within 22” that support HD, and are good too?
Thanks.
EDIT : I’m getting the AOC 2236Vw for 7700, No G2220HD or B2230 available. Need to know how well the AOC performs?
Also as I cant get my hands on the FSP PSU, I’ll be going with the CM Xtreme 350w for my rig thats as follows. Will it be enough?
Athlon X3 435
Gigabyte GA 880GM UD2H
Corsair 2 GB DDR3
LG H55N
Seagate 500GB
CM Xtreme 350w
Own the CM Elite 310.
My main questions are
1. What main problems do the CM PSU have other than the lower efficiency? because I think its better than buying Iball or Zebronics rite?
2. Will my rig be able to handle HD movies smoothly?
Thanks.
Athlon X3 435
Corsair 2 GB DDR3
LG H55N
Seagate 500GB
CM Xtreme 350w
