Power on Fans running but no boot no beep
Hi ,
When i power on my desktop
Cabinet fans are running , CPU fan is running , DVD writer & HDD is also getting power.
But there is no booting... there is no beep... monitor has no display.
I have tried doing the following :
I removed cmos battery and re-inserted it but still same issue
I removed HDD & DVD writer connection but still same issue
I removed both ram cards (i have 2 slots on mobo) , there is no beep even after removing ram and still same result....
CPU fan is running & Cabinet fan is also running.
I had kept my desktop running overnight for download.. it was a very big download and i doubt it would have completed it.. shutdown condition was set to "shutdown when downloads complete"
.... in morning it was in shutdown state.
I think of following 2 issues :
If anything could have happened at night i think it would affect PSU first..
(But CPU fan is running)
Since there is no.beep sound when there is no ram on mobo , i think its issue with mobo.
I dont have spare desktop or any spareparts i could check with.. what do you guys think ?? Is it PSU or Mobo or anythinf else ???
rijinpk1
Which psu you have?i suspect a mobo issue. Use bios jumper to load the defaults.
Also try one ram at a time.
Clean the ram slot and ram module.
Try ram on another pc
do you have a gpu?
V
Valve_Corporation
do you have a gpu?
Hi thanks for reply , i got SAGA 2 500w FSP...
Even am thinking somethings wrong with mobo ...
Trying out with jumper..
