NOKIA 6610i data cable problem.PLZ guys help urgently.....
mobilegeek
See ... I gave my DKU-5 to my friend ...
He transfered the wallpapers n ringtones sucessfully
So, what is that you really want to do with the Data cable??
M
medigit
i also wnat to transfer rigtones and wallpapers from PCto phone using DATA CABLE.But my Phone 6610i is not being detected by PC .Whenever i attach it , PC says unrecognozed USB drive or USB device has Malfuctioned ....PLz help
M
medigit
but the cable is not NOKIA original one . its a compatible one. So cant go to NOKIA CARE.Any more suggestions.BTW is there only one person in the entire forum with NOKIA 6610i data cable.
M
medigit
got the cable replaced by the shop keeper.But still the problem exists.By brother told that the problem os due to drivers , the computer is not able to find the proper drivers so it is displaying "USB device not recognzed" etc..
PLZ SOMEONE HELP>iNEED UR HELP BADLY.
mobilegeek
Dude .. I had to upload na .. I was busy the whole day
This works fine with my cable DKU-5
Part 1 *www.megaupload.com/?d=H2X9M5JQ
Part 2 *www.megaupload.com/?d=WNSWQEKL
I hope it works for you. The file are in .rar format.
M
medigit
downlaaded ur drivers.
Insatlled USb driver .Restart.
Installed DKU 5 driver .Restart.
Installed latest NoKIA PC SUITE .Restart.
BUT STILL THE SAME PROBLEM.
This pics will tell the problem.Plz have a look.
*rapidshare.de/files/9674236/usbproblem.bmp.html
and
*rapidshare.de/files/9674341/connection_problem.bmp.html
PLZ HELP ME. :(
mobilegeek
hey as i said .. see then there can only be two things
either the cable is faulty or the phone's port needs a repair
btw try the phone using someone else computer n cable
allmighty
whaaaa!!!! :shock: u should have bought the orignal one ! even i have faced some problems installing origanal ones (dku 2 specialy, not in dku 5 it installed in single try),may god help you with not orignal one.
mAYHEM
U have bought the data cable with Prolific 2303 bridge.U can only use Oxygen Phone Manager with this cable.Nokia Pc-Suite will not recognize this cable.Download OPM2 for nokia phones and drivers from HERE
M
medigit
so first install the prolific driver .restart.
Install OPM .Restaet.
then connect the cable and phone and PC together.RIGHT...
M
medigit
installed the driver .Prolific one.restart.
Instaled OPM 2 .But it is also not detecting the phone.
WHenever i try to connect the phone and Pc using a error message is given as shown in the below Picture.
*rapidshare.de/files/9796571/connection_problem.doc.html
mAYHEM
In OPM select the connection to F-bus/****{something like that},use the correct port and are the drivers correctly installed.On
