Need help in deciding mobo and cpu.
Ans:i will be gaming a lot bf3,crysis 3,tomb raider,total war shogun,sniper ghost warrior.and a little video encoding too...
Ans:10k and max of 11k
3. Planning to overclock?
Ans:yes
Ans:win 8
Ans:i already hav 2.2tb.so dont need any
Ans:screen size is 21.resolution 1440 x 900
Ans:i am planning to reuse my hdd,nzxt phantom 410,corair vs450 450w,asus amd 6670 2gb ddr3
Ans:two months
Ans:yup
Ans:chennai,ya i can buy online
Ans: all need is a suggestion for my "mobo and cpu".i alredy brought all the parts i mentioned above.only MOBO and CPU.
Cilus
laborare est orare
Fill yup this and post it here: *www.thinkdigit.com/forum/pc-compon...new-pc-help-answer-these-questions-first.html
sbnaul
Since you are planning to buy them after 2 months it would be better if you post the same 2-3 weeks before purchasing...
P
phantom uchiha
well i can buy them any time.if there aren't any good mobo's or cpu's coming soon.then i can buy in 2 days.since its low-midrange sector not many of 'em make it to the top even when released.so in that case there is no point to wait till 2 months..:wink:
P
phantom uchiha
The Gigabyte B75M-D3H does not offer any overclocking ability worth mentioning. With no voltage options other than vDIMM, and no ability to adjust Turbo multipliers, overclocking is just simply a pain!!
the same with i3-3220.i will be outdated soon if i cant overclock
but thx for the mention!
Tech_Wiz
Within your budget getting a Motherboard with Good OC potential is very hard. If you want to try Hand on OC then Cheapest Option is AMD FX4100 6.5k + Asus M5A97 7k = 13.5k BUT this will be SLOWER in all the Applications you have mentioned apart from the "little Video Editing". So your call..
Sainatarajan
^FX 4100 is not worth in in its price. The i3 easily beats it .
@ OP You wont get any oc facility config in that budget and also 2 GB Ram is useless for modern games. 4 GB Should be the least.
Add a Corsair 4 GB Value select to Ashish config.
P
phantom uchiha
ofcourse i will be upgrading my RAM to 4gb ddr3.
actually that is where my problem is...
the i3 easily beats the FX4100...but to get a good mobo(at that price point) i will hav to choose an AMD cpu..
so what i want is a capable AMD cpu to match the asus M5A97...well it would be good only if we had the FX-4300 in india..
so any suggestions for mobo to match the i3-3220??:-?
Cilus
laborare est orare
The Gigabyte B75M-D3H as suggested by others. i3 3220 is a locked processor and can't be overclocked, no matter how good motherboard you use.
P
phantom uchiha
so this is what i came up with...
gigabyte B75MD3H + i3 3220----------->gaming,no overclocking
asus M5A97 + FX6100------------------>a little less gaming,overclocking,good video encoding,future proof(??)
though the AMD build is going upto 13k i am starting to think its worth it..
I can use my M14x R2 for gaming.But for encoding i will hav to use my desktop(HEAT).
so i think AMD will do the trick.
Owning an a10 5800k doesn't puts a compulsion to use the igp. You can use any graphic card with it. Fx 6100 is a good processor, but not at that price. I3 3220 is a better option than fx 6100. Here, a10 is being suggested for being a good quad core processor, not for it's igp. A10 5800k is faster than i3 in multithreaded apps, especially those able to scale well on multiple cores. A10 is a better choice in low to medium gaming (even when equipped with a graphic card) as at low resolution, games are more cpu intensive then gpu intensive (although I'm still searching for a proper benchmark that can show the difference between i3 and a10, both with a graphic card).
P
phantom uchiha
I cannot find a decent mobo for A10-5800k that can bring out the best of it in my price range.
the ASRock FM2A85X Extreme6 will do the job,but is out of my price range:cry:
Any suggetions for A10 are appriciated!:mrgreen:
