issue while connecting LCD to Computer via HDMI .. problem !!
Alive_Hunter
I am trying to connect my Videocon LCD TV 19" via HDMI to my computer (Mobo : gigabite H61M D2H via HDMI).
On the LCD screen, i jus get blank screen displayed with 4095 X 768 X 60Hz displayed oin the corner of the screen.
I am clueless ??? wht should i do???
But when i connect the same to my Sony LCD 32" .. its quickly shows the display ...\
What might be the problem??
A
Alive_Hunter
When I select the other input medium on the LCD .. it says no signal....
concluded: it was some issue related to the resolution.
used VGA to VGA cable from computer to LCD. Now resolution detected 1024 X 768 X 60hz
thanks...
gameranand
Living to Play
Well you have to select input medium as HDMI. I do the same for my 4 year old PC at my village. I select AV for DTH and HDMI for PC. :)
A
Alive_Hunter
yes ... did the same thing as u said.... but still the same problem.
anyways .. the problem was solved ....used VGA to VGA cable from computer to LCD and selected the input method as VGA on the LCD.
