Is this temperature and fan speed right ?
clmlbx
In Idle state Processor temp is 52C but when on load like I convet movie to dvd it Goes to 68C. At 52c temp my fan run at 1150-1200 Rpm and at 68C it run at 3000 Rpm. IS this all correct or not
and motherboard temp for both Zone 1 & 2 fluctuate between 45-50. 2 is allways 2-3 degree Higher.
clmlbx
clmlbx
I forgot to mention My Processor is core2duo 1.8 ghz (800Mhz Fsb) and my MB is Intel D946GZIS
surinder
Tech addict
No these temps are above normal so make efforts to pull them down. Take clues from this thread to how to lower the temperature of your processor.
*www.thinkdigit.com/forum/showthread.php?t=118558
chesss
mera kutch nahi ho sakta
the fan spins faster , when temperature is high. So your fan speeds looks normal
clmlbx
clmlbx
^^ Some1 pls confirm it ..... ya It shows fan is working but when I actually see it (fan while running) looks it is realy slow then normal.
jeetu
CPU temp can be reduced by arround 10 C with good ventilation. A good rear exhaust fan and side intake fan can do wonders with CPU temp. My E5200 CPU has around 35 C idle temp and 48 C at full load.
