Re: I need help in building a PC for my son (in 10+2) for beginners in animation fie
thankx a lot 4 ur reply but do tell me how do i need to improve over the above the above is costing me 30k
is the Phenom II X6 1050T @ ~10k a black edition .....? & the mother board u suggested is it SLI & Crossfire Compatible .....? coz i m afraid if the mother board gets out dated its very fatel
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
neways why did u ask me to not go for a Cooler Master SMPS is it not ok i was going for a CM Elite 310 Cabinate with SMPS what do u say .....?
and i want 2 change the Graphic Card to XFX ATI Radeon HD 5770 (1GB) how is that ....? & i had selected the Processor 965 (3.4GHz) coz it was the best among its class of Black Edition Processors whats worng with it i just have a budget of "40K Max"
you can improve by going for GTX460 1Gb.
no. 1050T isn't a BE. but its Overclock potential is terrific. can reach 3.5ghz easily. the board doesn't support Xfire or SLI as it have a single PCIeX16 slot.
why did you say its fatal if its outdated & doesn't support multi GPU solution? i didn't get you at all.
Cooler Master Extreme Power PSU lineup prone to damage. they blow up when put under load or even under normal usage. also i doubt Cooler Master will provide warranty on blown PSU. add to it, if a PSU goes up, chances are it'll damage the board, proccy & the graphics card which the manufacturer won't provide warranty as its damaged by spike.
if you go for the Real Power or Silent Pro, Corsair, Seasonic are better choice here.
XFX ---> always have heating issue. Rashi Peripherals, distributor treat customers badly & deny RMA mostly. its like kicking your own @$$.
HD5770 ---> no CUDA/PhysX. good for gaming but not so good when coming to animation use.
are you going to overclock? if yes than get the X6 1055T. even if you don't OC, X6 1055T suites your apps more. they need more thread, not more speed. also 965 is badly priced.
