i gt problem in C Program again !!! HELP ME PLS !!!
ImBeck
How do you exchange or swap TWO (2) variables A and B with using a
third or temporary variable?
C program (Attach TWO (2) sample output for each program)
JUST SHOW ME 2 EXAMPLE OF C PROGRAM
QwertyManiac
Commander in Chief
How's addition and subtraction less expensive than an XOR? You've learned your computer architecture properly, haven't you Garbage? :p It would result in more gate delays than a simple xor.
Garbage
God of Mistakes...
I thought he meant "raise to" :|
thought it's algorithm than statements...
gary4gar
GaurishSharma.com
yep, Bitwise operations are fastest.:)
but this things are never taught in our education system
what we learn is using a two and a half decade old program called "TC" :(
cooldip10
a thread named "HOMEWORK HELP" must started :D
This will save space + other's problems can be reviewed without having to use the search engine
jal_desai
dont u think the question deserved no more than 2 posts.. (this applies to me also for posting this useless post) :D
