It's because the 32bit OS supports the limited B/W so data transfer is limited....
For faster performance try using the x64 bit OS.....
Try this links I'm sure you will get an idea mate !
*support.microsoft.com/kb/294418
*www.w7forums.com/windows-7-64-bit-vs-32-bit-t484.html
