ashis_lakra
Gaming Unlimited
Hey folks,
Is it really harmful to run 3D Mark 11 and 3D Mark vantage v1.1 on a PC ?
It stresses the computer parts, but running once shouldn't be a real trouble. But I am facing the trouble.
After completing the tests, then just browsing computer i faced the following problems :
1) PC was able to multi-task, but now when i run 4-5 programs.. the PC Is slowed like a Pentium III system. The mouse busy icon shows continuosly for more than 10 mins.
2) Then BSOD's appeared, upon which restarting didn't detect my Hard Disk in bios, so Boot failed. Turning the whole computer off for 1 min , solves the problem. But booting time has drastically increased to double time.
3) Some application setup icons in my folder doesn't show default icons, so if i keep open that folder for some 1 min, and try to copy even a 5MB file from any place to other place, the system hangs.. then after 2-3 minutes, BSOD.. again
4) Sometimes, the CPU- widget doesn't seem responsive whereas GPU widget seems fine. so is my new processor failing ??
5) I have done Cinebench test, and the score dropped from 5.31 to 5.29 .. Is it really the new processor culprit ??
6) Currently running HD tune pro to check whether my Hard disk has bad sectors, but its showing 0.0% damaged, no bad blocks till now..
Even formatted my PC for 4 times within last 12 hours, and the problem persists, i guess those tests made my PC life terrible.
