Help me in Building a system for working on Visual Effects Editing Software's !!
s0rdfish
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: I m a Student doing my VFX Diploma & My Purpose for working on (Visual Effects) Editing software, Maya, 3dMax, nuke, fusion, Photoshop, After Effects, PremierePro Music Editing software... But working More on After Effects, Premier Pro, Nuke, Fusion, boujou, Etc (Playing Games too :p)
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: YES
3. What is your MAX budget?
A: 40k to 45k Max
4. Planning to overclock?
A: NO
5. Which OS are you planning to use?
A: either xp64 or windows 7
6. How much hard drive space is needed?
A: 500GB
7. What resolution will the screen run at & whats the size of the screen you want?
A: 20" or 22" HD
8. How would you rate your hardware knowledge from the count of 1-10? (1 being the lowest, 5 being you are somewhat in sync with the current performers and 10 being the highest)
A: 7
A: assembler
10. When are you planning to buy the system?
A: within this month
11. Are you one of the types looking out for "future proof" configurations?
A: yes
12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention.
A: I have Keyboard, Mouse, Ups, DVD writer. ( took 3 months back)
13. Which city do you live in and are you open to buying from shops from other city/states?
A: Yes. Bangalore
14. Mention any other points if deemed necessary
A: my budget is only 40k to 45k frds so please give me the best system configuration for Price given above
---------- Post added at 07:07 PM ---------- Previous post was at 07:05 PM ----------
Thanks & Regards :toast:
mavihs
Techie By Heart
too less! you need double of that for a decent config or your rendering will suffer a lot!
try to increase you budget to atleast 50K!
s0rdfish
s0rdfish
Frds i have only 40k but i can try max to 45k frds plzz help me in giving me best config for a PC
---------- Post added at 03:31 PM ---------- Previous post was at 03:30 PM ----------
Hello mavihs thx for ur reply soo i have only 40k now but max i can try 45k
clmlbx
Phenom 2 X4 945 @ 6900
Gigabyte Ma785gmt-us2h @ 5200
Kingston 4 gb DDR3 1333mhz @ 5200
CORSAIR CMPSU-550VX 550 @ 4800
samsung B2030 @ 6500
Nvidia GTS 250 1gb DDR3 @ 6800
Cabinet :- wait for others reply (dunno about it)
U will need a good cabinet wih very best cooling system ..dunno know about that so wait for others suggestion.. Me don't have much Idea so wait for other suggestion before buying....but remember few things 40-45k is enuf for learning purpose and making show reel.. but for commercial purpose it is nothing.. buy Graphic card of nvidia only as it's cuda an physics will help u out .. soon rendering will be card based so .u will have a advantage..
I have used max on c2d 1.8 ghz , gts 250 , 2gb ram.. for learning and showl reel it is good ..I believe..well bought new system 3-4 days ago.
and recheck ur ups after all this upgrade can it give enough backup
s0rdfish
s0rdfish
frd thxx for replies so tomorrow i m going to buy my new system and this is wat i have decided plzz let me know if changes needed
amd phenom ||x4 965 do i need Cooling fan for AMD Phenom ||X4 965 ( How is AMD Phenom || X6 1055T ?? )
gigabyte GA Ma770t-US3P ( but still not sure which motherboard to buy for amd phenom ||x4 965 help needed how is gigabyte GA MA785GM-US2H Or GA785GMT-USB3)
Kingston ddr3 ram 4gb
Seagate 1TB hard disk
Dvd writer LG
Keyboard and mouse Logitech MK200
Aoc 22" full HD monitor
Graphic card Zotac GTS 450 ( plzz suggest me other GP if this is not compatible with motherboard)
Cabinet-- not yet decided
Power Supply- Need help which one to buy
If possible can i get pricing for above and my budget is 40-45k max
J
Joker
Guest
How is AMD Phenom II X6 1055T ??
i will suggest you to go for this as this is a great processor for your job.
(plzz suggest me other GP if this is not compatible with motherboard)
every PCIe graphic card is compatible with every motherboard having a PCIe slot.
AMD Phenom II X6 1055T @ 9.4k
Gigabyte GA-880GM-UD2H @ 4.5k OR MSI 880GMA-E45 @ 5.5k
Seagate/WD 500GB Hard disk @ 1.9k
2*2GB DDR3 1333Mhz Kingston RAM @ 4.6k
Corsair VX450 PSU @ 3.7k (only this)
Cooler Master Elite 430 cabinet @ 2.5k or NZXT Gamma @ 2k
Zotac GTS 450 1GB @ 7.5k
LG DVD Writer @ 1k
BenQ G2220HD @ 7.5k
Logitech keyboard + mouse combo @ 0.5k
Total = 45k.
Cilus
laborare est orare
Rather than going for the AOC 22" full HD, you can also go for BenqG2220HD. It is also a full HD monitor and priced more than 1k less than the AOC one. I personally own it and it is a very good one.
The price of it in Kolkata is 7.3k + 4% tax
J
Joker
Guest
^ important thing...avoid Coolermaster PSUs which most shopkeepers will try to sell. only go for Corsair vx450 as it is the best!
Jaskanwar Singh
change the graphics to msi gts450 cyclone @ 7.8k
corsair cx400w @ 2.7k is sufficient. vx450 is not needed for that config!
avoid that msi mobo. this will allow you to spend some more on another 2gb ram stick @ 2.3k. 6gb will be nice for your work.
avoid seagate. get WD only.
s0rdfish
s0rdfish
So frds will is config go well for my Editing software's and Few Games if possible ?
LG DVD Writer @ 1k
BenQ G2220HD @ 7.5k
s0rdfish
s0rdfish
can anybody give me the bangalore (SP Road) pricing for the following items
Seagate/WD 500GB/1TB Hard disk
corsair cx400w
Cooler Master Elite 430 cabinet or NZXT Gamma
msi gts450 cyclone
LG DVD Writer
BenQ G2220HD
Thanks in advance
