Help me choosing 22'-26' LED TV
Topic says all, I have finalized this model of LG :
LG 22LE5300 22 inches LED TV Rs. 17,550
Features
LED Backlighting
High Definition Resolution
3M:1 Dynamic Contrast Ratio
Picture Wizard II (Easy Picture Calibration)
Smart Energy Saving
ENERGY STAR 4.1 Rated
AV Mode (Cinema, Sports, Game)
Clear Voice II
ISFccc Ready​
Model No.
22LE5300
Dynamic Mega Contrast Ratio (10,00,000:1),DivX thru’ USB 2.0,3X HDMI (ver. 1.3 deep colour),Response time 4 ms,Clear voice II,Surround System (Infinite Surround),PC Connectivity,HD Ready
Can you guys suggest me a LCD-LED tv within 18k. Cant extend my budget so a 22' or 26' will suffice my needs. How's the quality of LG models ?
Thanks again.​
rajan1311
who so much excitement over LED ? Why not get a good 24" IPS and hook it up with a GOOD external TV Tuner box, will turn out to be cheaper than this,or around the same.
rajan1311
well rajan, led backlighting method is getting implemented in ips panels as well.
I think you did not get my point....most of the LED monitors are just edge lit...
Which IPS come with an LED backlight? nt seen 1 yet bro...
Just use a monitor as a TV na? Connect TV Cable to TV Tuner, TV Tuner to monitor, use the remote that comes with the TV Tuner...thats it? A decent 24" Full HD Monitor will cost you around Rs13.5k. You can get a good tuner for some Rs3k, and dats it.. :)
I have a cheap external TV Tuner,got it for just Rs400. Fairly basic functions but does the job :)
