windchimes
Can you hear it..??
Hello digitians
I 'm planning to buy my first DSLR asap. I'll be using the cam for all kind of photography say scenery,people portraits,macro, low light etc. Also, I am fine with doing slight post works using image editing tools . The amount I would like to invest maximum would be around 35k.
After looking around I came to the conclusion that Nikon D3100 would be a good choice. One dealer offered the same for Rs 28.5k with the 18-55mm usual lens that is part of the package. And I am planning to buy a zoom lens ( 70 - 105mm ) which according to the dealer costs around Rs 6k.
( Another option I considered was to look at Canon 500D as well as 550D. The former comes for around 33k but came to know the manufacturing of the same came to a halt while the later comes for 35.5 k approx ).
Is my choice good enough and will it serve my purpose? Or do you have any further suggestions? Also thought Nikon would be better since the majority said it is more user friendly for a newbie or say who isn't a pro.
Looking forward
Looking forward
