help! 1600mhz ram running at 1333mhz.
phrick
my 2x4gb of hyper x blu 1600 mhz ram (KHX1600C9D3B1/4G) on asus m5a97 r2.0 is running at 1333 mhz speed, what should i do?
*s10.postimg.org/5ub84n2jd/ram_issue_bios.png
should i play with the memory multiplier and bring it to 1600 mhz? will this damage it?
SunE
Professional Newbie
And Motherboard?
asus m5a97 r2.0
OP mentioned it already.
@OP make sure your RAM timings are 9-9-9-24. I had the same problem with my RAM and changing the RAM timings worked for me.
EDIT: Hmm after looking at your screenshot I see that the timings are already 9-9-9-24 :p
P
phrick
asus m5a97 r2.0
so what do you suggest i should do? do you think the ram modules might be faulty?
Cilus
laborare est orare
I think the Motherboard is having UEFI BIOS. In the BIOS menu, under AI Tweaker section, you will find the option to select DDR3 Ram speed. Select DDR3 1600 from the list. Now go to the DRam Timing control setting and set the CAche Latency values to 9-9-9-24-33-1T
P
phrick
also i found out that my ram modules are actually 1.65v (@1600mhz) and 1.5v (@1333mhz jedec). should i increase the voltage too from 1.5 to 1.65? could this damage it and the cpu?
1.65v mem voltage won't damage the cpu/mobo or the ram module but first see whether it runs without any issue at 1.5v or not - only then think about bumping up the volts.
