Yeah I its a long time that I have cleaned my laptop. Also haven't applier thermal paste since I bought it.
What do you think of this thermal paste ? Is this one good ? Any other suggesstions ?
Amazon.in: Buy Cooler Master V1 IC VALUE THERMAL COMPOUND Online at Low Prices in India | Cooler Master Reviews & Rating
Ok but should I buy from amazon ? Or should I go with primeabg ? I don't want fake product.Go with the following Thermal Paste:
Noctua NT-H1 -425.
Link:Buy Online | Noctua NT-H1 Thermal Compound | in Indi
Did you fix your laptop heating?Hi, I have HP DV6-6165tx and I have used Noctua NT-H1 twice in the span of 5 years. I have never noticed any temperature difference after applying the paste. Temperature goes over 90c and the bottom side of the laptop is so much heated after prolong use that it becomes hard to keep it on lap. I had cleaned the laptop around 6-7 months ago but now even running MS OFFICE makes the laptop so hot. Should I re-apply the expired Noctua or should I purchase a new paste like THIS. Sometimes I also feel like something is burning but I doubt that. Any help would be appreciated. Thanks.
Newer version is available on primeabgb(check product code):Guys, where do you buy thermal paste from?
Was looking into MASTERGEL MAKER NANO GREY COOLER MASTER but it seems to be OOS.
Don't want to get Kryonaut (or those with <11 W/m.k thermal conductivity) because of uneven mounting pressure and laptop easily reaches 85 °C on full load.
560 for "newer" version MASTERGEL MAKER NANO GREY COOLER MASTERNewer version is available on primeabgb(check product code):
Buy Online Cooler Master MasterGel Maker CPU Cooling Thermal Paste MGZ-NDSG-N15M-R2 - in India
I'll call them today. Vedant is charging >120 for shipping ( while speedpost is ~40 and I have a post office within walking distance)Forget about anything outside of major brands for thermal paste in India as they cost a lot more because of import duties & non-official status here.You can try asking primeabgb & vedant for older version but other than that your only option is to pay the extra 200 for this brand.
I only see people using thermal pads for VRMs on ryzen mobos doing above average overclocking,is it really required for your laptop.
$50 as delivery chargeYeah same here, jackly stuff is cheap but not durable.
I believe this is an ifixit clone but not sure if it will reach india
*www.aliexpress.com/item/1005001764...earchweb0_0,searchweb201602_,searchweb201603_
That is old laptop so not sure pushing it too far would be a good idea.While playing game on the old Samsung NP550P5C laptop, the temps went to 92C after which it started throttling.
I installed Throttlestop to undervolt it but I am not seeing any option FIVR. Can I use just Clock Mod option on the main window to reduce the performance from 100% to some 90% ? Will that help in controlling the temps without losing too much on performance?
Watch guides by Bob of all trades, just in case.While playing game on the old Samsung NP550P5C laptop, the temps went to 92C after which it started throttling.
GPU temps are always fine. I think re pasted the CPU and GPU last year with IC Diamond. I just thought undervolting will bring the temps down that is why I want to try this instead of opening the laptop again. According to the throttle stop guide I am unable to find the FIVR option.Watch guides by Bob of all trades, just in case.
Anyways, raise the back of the laptop to improve airflow from bottom vents. Try undervolting GPU using MSI afterburner. If you can, just repaste the CPU & GPU. Likely this is the issue causing overheating.
