pkkumarcool
Game & anime Lover
I meant compressed air cans like this one Amazon.inBlow the dust off with the blower? This would not do a good job? What kind of vacuum cleaner is needed ? Any link will be appreciated.
The liquid is usually of low quality, I think using Colin is better. Get microfiber cloth from amazon and use it for screen. Don't use liquid for components like motherboards with capacitors and suchHi guys! I have huge dust problem here in the house and wish to keep my PC clean from the dust to avoid heating issues.
Will this kit help:
*www.amazon.in/gp/product/B01IBVCUNO/ref=ox_sc_saved_title_1?smid=A14CZOWI0VEHLG&psc=1
I need a cleaning kit which can be used to clean desktop and laptop both. Desktop takes higher priority here. I will open the cabinet and use blower to remove dust from the components. I think I should not use the brush but I am not sure. Also, if the kit has cleaning solution to clean monitor then it will be great.
For such processors any decent entry level thermal paste should work fine.For - Intel® Pentium® P6100 2 GHz and Intel(R) Core(TM) i5-4200M CPU @ 2.50GHz
which Thermal Paste from the list
amazon.in/Cooler-Master-CryoFuze-Thermal-Compound/dp/B07TWL1H29
- 14 W/m-K
- 11 W/m-K
- 8 W/m-K
- 5 W/m-K
Any other brand recommend?
