fan noise problem
abhishek_sharma
i've just assembled a 2.8 ghz Pentium D procy......earlier i was using an amd sempron 2500+.....ever since i've switched this thing on, it is making much more noise compared to my earlier procy
is this natural or is there any fault with my fan instllation....
s18000rpm
ಠ_ಠ
is it from Procy. fan or SMPS fan.
if procy. fan, check whether RAM is fitted properly, & check for loosely connected cables.
harikatt
try using screw up tightly with the cabined... and also avoid the touching of wires and cables inside to the fan...
