Fan for Zebronics Bijli cabinet
sona
I have got a Zebronics bijli cabinet but it doesn't have proper ventilation facility.
I want to install a rear fan for the cabinet but a 120mm fan doesn't work for me as the space provided is too less for a 120 mm fan. Also it is large for a 80mm fan.
Can anyone tell me the proper fan size for the rear side????
Zebronics Bijli cabby has enough space to fit a 120mm rear fan as I'm using a CM 120mm fan with that cabby - so you can count on that :p
max_demon
IM AS MAD AS HELL!!
i think in the newer sets they have decreased the fan size because imo it DOES not fit 120mm fans , i have same cabby Btw
Krow
Crowman
@OP go for a 90mm fan of the highest CFM you can find in case 120mm doesn't fit ur cabby.
That very odd. I have bought 4 of'em so far. All of them supports 120mm fan at the back :p
BTW, if it does not fits 120mm fan then the only option is to go for 80mm fans. They can be bagged for as low as Rs. 40 :p
