Dr. Divx Settings....need help....
Alive_Hunter
Hi to all,
I need to convert the .dat (Movie files) to .avi using Dr. Divx.
So i need some suggestion...i searched through the forum but did not got the req info...
generally a movie contains 2 cds (.dat)
i need to compress this to avi so that i can fit to a single cd with a good quality video.
1. What shold be the setting for Dr Divx.
2. Which Compressing Codec should i use.
3. wht should be the birate ....and so on...all the technicall settings...
Is there anybody using Dr Divx in this forum who can guide me..
Also i what to convert the movie DVD to a single Avi file of about 700MB
Please guide me... Thanks..
Regards,
Alive Hunter
domin8r
Now a buddy of mine is a huge compression nut, so I can't stand up to his level of knowledge, but straight up I can tell you something. Try to use VirtualDUB [*www.virtualdub.org] instead of Dr. DivX. I agree that the good doctor is a much better option if you're just starting out, but VD offers you levels of tweaking DD can't even dream of. As far as a tutorial goes, this one should work just fine: [*download.divx.com/guides/QuickStart-EN.pdf] The best part of it is, that VirtualDUB's free and supports a host of community plugins.
You can find more at the online guides section:
[*www.divx.com/divx/create/divxpro/guides/]
You'll also find the right steps to follow to merge two video files to make a single one.
Hope this helps.
shovik
Banned
Try Virtualdub from *www.virtualdub.org
and then after installing virtualdub go to the link below for total conversion procedures.
*www.doom9.org/index.html?/virtualdub_procedures.htm
and if you want Dr.DivX settings then head to the guide for Dr.DivX at ::
*www.videoforums.co.uk/guide-dr-divx-56.htm
Hope this would help u out.
Regards,
Shovik.
