A
amit.tiger12
Guest
I was using net on computer. Suddenly black screen came like we see in windows error screen showing "sad smiley". After that it automatically restarts and black screen on boot-up was showing "disk boot failure, install system disk".
This happened lots of time, "while using computer black screen came and comp restarts, then that disk boot failure error". Everytime this happened I removed the connection of hard disk ie. sata cable, power cable. And tried by reconnecting other sata port (there are 4 ports). After trying so much, it starts.
Computer repairer told me that hard disk may have bad sectors that are causing them. So I checked & repair bad sectors through "Hiren's Boot CD". It repaired most of bad sectors, but problem occurs sometime. If computer working fine today, after sometime "disk boot failure".
In 2014, I never had such issue of disk boot failure, but yesterday I was installing windows 8.1 and beep sound came and setup was stopped at 35%. Removing and reconnecting hard disk connection solved the problem.
So, how do I solve this problem??? Do I have to buy new hard disk.?? Motherboard?? or Power supply??
I am using Hard disk from 2006, changed motherboard 2 times, asus(1 time), and now gigabyte(1 time).
