ankurya1985
Rockstar In Nothing
Hello ,
Firstly here is my configuration :-
Intel Pentium D 805 Processor
Intel D102GGC2 Mobo
XFX 8600 GT 512 MB PCI-E card
2048 MB Ram
Hitachi 160 GB Sata & Seaget 80 GB ATA drive
Frontech PSU 450 Watt
And using 5 fans (including CPU`s and PSU`s)
So here is my problem my CPU and GPU are very high in Temprature .
Please see the pic :-
*i43.tinypic.com/s6rwww.jpg
I am confused here also as u can see SPEEDFAN is showing
CPU-50
Remote-63
But my bios says
CPU-63
Remote-50
i dont know which one is correct may be the BIOS because it is integrated .
Anyway the temprature is too high to handle some application Including Games *tech2.in.com/forums/images/smilies/icon_mrgreen.gif
So i need your suggestions to getting it cool down . I already done some work on the cables for the Airflow and made a lot of changes to it *tech2.in.com/forums/images/smilies/icon_rolleyes.gif if you want to see i can show some pics so u can suggest more about it Also if Watercooling is available in india then i will go firstly with it if it is not too costly . My budget is 5K. if not i can also go with asus`s v60 and some more that available in their website .
Hey i one more thing i need to tell you about , i just come to know that the processor i m using is one the world`s best overclockable processor it can be overclocked from 2.66 to 4.2 *tech2.in.com/forums/images/smilies/icon_eek.gif so i need a decent cooling system for my entire cpu including GPU .
Waiting for your response................
Intel D102GGC2 Mobo
2048 MB Ram
CPU-50
Remote-63
But my bios says
CPU-63
Remote-50
