First do you Have Tv-tuner..If yes then Which, Pls update make and model no of Tv -tuner. If not and you wish to buy then their are many available between 1-1.5K.. with Vga ports in it.. just connect monitor and you are on.
Thanks a lot for replied me.
I have front tech tv tuner. i am unable to find it's model number. so posting here it's features and specifications
Features
Upto 1920x1200 High defination resolution.
Fully compatible with all LCD monitor and CRT with low resolution.
TV tuner with frequency phase lock (PLL) to offer stable reception;
Channel number ordering function allows you to change the sequence of channels as you prefer
Support 4:3, 16:9 and 16:10 PS aspect ratio
Best Image Quality with 24 bit color
3D image noise reduction
Moveable PIP function for TV window in PC desktop.
Multi Channel preview up to 16 Channels
Still-picture function
Calendar/ calculator/ game functions & auto power on/off by alarm within 24 hours
Video input can be used to connect external equipments such as DVD
Full-functional IR remote control
Compact Size and low power consumption, energy saving System requirements
No specific PC system required.
Monitors(LCD,CRT,PLASMA,PROJECTOR)with VGA Input
Video Input device(Cable/Antenna,VCR,DVD,LD player etc.)
Specifications
Power input: DC 5V/1000mA
Input Signal: RF input: 47-870MHz,RGB,Composite Video
Audio: PC and R-L in.
Video Format: 1Vp-p (PAL/ NTSC)
Panel Controls: Channel +,-,Volume +,-, Menu, Power, AV/TV.
Resolution(optional): 800*600/1024*768/ 1280*1024/ 1440*900/1680*1050/ 1290*1080/ 1920*1200
RF output:Horizontal frequency: 37KHz-75KHz
Vertical frequency: 60Hz (refresh rate)
Timer ON/OFF function.
and monitor is 23 inch Acer. which is having usb, hdmi, lan cable, speakers jack ports.
