Computer for 50K budget [no GPU] [only cabinet parts]
A
amit.tiger12
Guest
You can save some bucks and use it on other components. There is not much performance difference between i5 4690 vs i5 4440 so go with i5 4440.
Go with the following Config:
ProcessorIntel Core i5 4440 3.1Ghz12,500
CPU CoolerCooler Master Hyper TX3 EVO1,700
MotherboardMSI H97 PC Mate6,500
MemoryCorsair Vengeance 8GB(4GBX2) 1600Mhz5,400
Graphics CardZotac GTX 970 4GB DDR526,000
Power SupplySeasonic M12II 520 EVO Edition(Fully Modular)6,000
CabinetCorsair SPEC-013,700
Internal StorageWD Caviar Purple 2 TB6,000
Optical DriveAsus-DRW 24D3ST DVD/RW1,100
MonitorDell S2240L 21.5" LED IPS8,000
KeyboardCooler Master Devastator Gaming Bundle2,500
MouseIncluded in combo0
Total79,400
1. i5 4690 vs i5 4590 vs i5 4570 vs i5 4440 ?? which is better??
I don't want any cooler.. :)
fine with stock.
2. Gigabyte GA-H97M-D3H vs MSI H97M-G43 vs MSI H97 PC Mate vs Asus H97M-E ??? which is better???
3. strix 970 getting from friend shop @27K with some titles. Zotac GTX 970 (@26K) vs Asus Strix 970 (@27K) ??? which is better??
4. thanks for suggesting modular edition, but what is EVO Edition? is it better than "S12II 520/M12II 520 normal edition" ?? what about local availability? buying from Lamington Road, Mumbai..
5. Corsair SPEC-01 vs Deepcool Tesseract ?? what about local availability? buying from Lamington Road, Mumbai..
6. WD Caviar Purple is for surveillance... only 2, 2TB products available @ affordable price, Seagate Barracuda 2 TB vs WD Caviar Green 2 TB ???
Please help here friends...
[MENTION=145143]SaiyanGoku[/MENTION]
[MENTION]harshilsharma63[/MENTION]
[MENTION=135617]rijinpk1[/MENTION]
[MENTION]adityak469[/MENTION]
[MENTION=300035]UndercoveredKnight8492[/MENTION]
[MENTION]HE-MAN[/MENTION]
[MENTION]Nerevarine[/MENTION]
[MENTION]bssunilreddy[/MENTION]
[MENTION]quicky008[/MENTION]
fine with stock.
@SaiyanGoku
harshilsharma63
@rijinpk1
adityak469
@UndercoveredKnight8492
HE-MAN
quicky008
1. Intel Core i5 4440 @ 12.5k is better.
2. MSI H97 PC Mate @ 6.5k is better.
3. Zotac GTX 970 @ 26k is better??
4. Seasonic M12II 520 is itself called as EVO Edition. You can easily get it in Lamington Road, Mumbai.
5. Corsair SPEC-01 is easily available at Lamington Road, Mumbai.
6. WD Caviar Purple for Surveillance. There is no such thing as a particular HDD used for such & such purpose. WD is very good and their ASS is also good and affordable. Dont go with Seagate and WD Green as green has high rate of failure these days.
7. You can get the above PSU and Deepcool Tesseract SW Cabinet(Long GPU's wont fit in this cabinet) from overcloclkerszone or Tirupati Enterprises who are the Official Distributors for India as well as who takes care of RMA also. OK.
8. Try to get all the components locally as you will get less prices and in one shop right.
WD Black>Blue>Red>Purple>Green ( This is how WD HDD stands)
Shah
[MENTION=105611]bssunilreddy[/MENTION] WD Purple CANNOT be used as primary or secondary HDD unless the OP is fine with frequent corrupt data in his HDD.
These drives are designed for "it's more important to complete the read or write in the specified time frame than that the data written or read be correct" usage. Pretty much the opposite of what you want in a NAS that stores important documents, business data, treasured photos/videos, or anything except short-lived (days, weeks) streamed data.
Synology Forum ? View topic - Western Digital "Purple" hard drives.
ZTR
I have been using WD Purple for over a year now as my primary OS drive and I haven't faced any corrupt data in my HDD
Also unlike Blue or Green,Purple comes with a 3 year warranty
A
amit.tiger12
Guest
can anybody tell me which gaming headset to buy, over the ear with mic...???
I considered SteelSeries Siberia v2, is it a good choice???
price around 6k on flipkart..
A
amit.tiger12
Guest
but my budget is around 4k max... please suggest me best headset for gaming with mic...
@HE-MAN
@Nerevarine
@quicky008
A
amit.tiger12
Guest
I'd rather use IEMs having good noise cancellation with a mic instead of a bulky headset but that's just me.
what about SteelSeries Siberia v2?? but price is high around 6k.. out of my budget..
1st decided SteelSeries Siberia but found SteelSeries Siberia v2 better option...
2. any specific reason to buy MSI H97 PC Mate??? pc mate is ATX size and i will not go for multiple gpus...
confusion over gigabyte and msi :( ?? which is better??? UI, software (mobo soft) and service wise?
GA-H97M-D3H and MSI H97 PC Mate and MSI H97M-G43 (as mentioned in buying guide)??
*www.gigabyte.com/products/product-page.aspx?pid=5258#ov
Motherboard - The world leader in motherboard design
from which shop to buy in lamington road mumbai?? there are lots of shops...
My friend suggested me PC Guide Shop...
A
amit.tiger12
Guest
hey buddy, i went to check prices of this config. and prices are good comparing online...
but some products are discontinued according to them, and they don't have it.. searched almost all shops in lamington road.. :(
keyboard & mouse = Cooler Master Devastator Gaming Bundle, cabinet = Corsair SPEC-01, headphone = Steelseries Siberia V2 gaming headset... these products are not available and discontinued according to them.. i don't know...
@bssunilreddy told me that try to buy everything from one shop and locally..
because of unavailability or product discontinued @lamington, keyboard mouse, cabinet & headphone need to buy online.. what should I do???
I can get these things in one shop only..
Asus strix gtx 970 @26.5K
i5 4440 @12.2k
Corsair Vengeance 4GBxX2 1600Mhz @4.2K
MSI H97-G43 @7.5
Dell S2240L 21.5" @7.8k
Seagate Barracuda 2TB @5.8K
Seasonic S12II 520 @5K
rijinpk1
if they are unavailable locally, your only option is to get it online. make sure you purchase it from trusted sellers. instead of devastator combo, i would prefer, logitech g105 and g400s combo.
A
amit.tiger12
Guest
Re: Gaming for 80K budget
Can someone tell me is this computer good for graphic designing? And video editing?
What changes i have to make in quotation?
