din4204u
guys i have a system with following specifications
amd sempron 2000+ at 1330 MHz on ecs km400-m2 mobo
2x256 mb ddr400 ram
250gb hitachi pata(recently added)
80gb hitachi sata
benq drive
350 wt local power supply with 16A on +12 v line.
i have win xp with via 4 in 1 and via hyperian pro latest installed
problem:-
wenever i make nero image of any disk its success ratio is 1/3
and when it fails my system just hangs.it never shows any message or something.mouse stops working.everything justs hangs.and it is like with every cd.either it sucessfully create images or it hangs the system.
but most intrestingly it only hangs it above 60 % of image creation.
forexample it hangs on 65,72,88,99,100 but never below 60 percent.and when it hangs even the spining of cd in drive goes to ideal.
and sometime but quite rare it hangs the same way in extracting something from iso or any other ziped images or files.but it happens quite rare.
wat i have done so far:-
1:-i replaced the system with 2 drives of my friends but same problem
2:-i replaced the system with 3 diff type of ram brands from my friends
but same problem
3:- formatted system and had a clean install of xp again i m with same
problem
4:-i have replaced cdrom cable with a fresh one but same problem.
my questions:-
1:-shuld i change my via hyperian latest drivers to some old versions
2:-is it possible that my power supply is at fault.
any kinda help wuld be highly welcomed.
2x256 mb ddr400 ram
80gb hitachi sata
benq drive
problem:-
but same problem
problem
my questions:-
